Pete & KW related Help...
Threads
- vibration damper thoughts (59 Replies)
- 7" or 8" Stacks? (2 Replies)
- Firewall push air fittings (12 Replies)
- Kenworth t680 derate mode (1 Reply)
- Suspension lop sided (4 bag) (12 Replies)
- Suspension dump (12 Replies)
- Overheating (5 Replies)
- Paccar ESA (17 Replies)
- Another dumb question (31 Replies)
- SmartNav gauge change/add (2 Replies)
- W900 ambient air temp sensor (3 Replies)
- W900 Hood Adjustment (4 Replies)
- KW Check engine, regeneration completed but insufficient (4 Replies)
- Iron high in sample (13 Replies)
- Pete 579 no crank no dash powerup (4 Replies)
- Outside air temp fault code (1 Reply)
- Kenworth smart nav acting up (1 Reply)
- Retirement not working (13 Replies)
- 2016 Peterbilt 587 Electrical problems (13 Replies)
- front turn signal, daytime running and fog lights in-op (8 Replies)
- Brake Light Issue - 2013 T800 (2 Replies)
- Headlight issues (13 Replies)
- W9 humidity (12 Replies)
- Manual Steering (10 Replies)
- 2016 Pete 389 interior/cecu problems (8 Replies)
